Sapele for neck and tail blocks? http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=24589 |
Author: | Corky Long [ Sat Nov 14, 2009 3:25 pm ] |
Post subject: | Sapele for neck and tail blocks? |
I've got some Sapele from the local lumber yard at a very resonable price - in blocks that can easily be cut into neck and tail blocks. I'm assuming that the properties are very similar to Honduran Mahogany and as such can be used as a substitute for Honduran in neck and tail blocks. Reasonable assumption? Thanks. |
Author: | James W B [ Sat Nov 14, 2009 3:40 pm ] |
Post subject: | Re: Sapele for neck and tail blocks? |
I`ve used them with no problems.I`ve also used Khaya with no problems.I`m pretty sure LMI sells them,so they must be fine. James |
Author: | P@uL [ Sat Nov 14, 2009 5:51 pm ] |
taylor is using sapele necks now and its a good substitute. |
Author: | JRessler [ Sun Nov 15, 2009 5:42 am ] |
I've been using sapele for end blocks and necks for some time now. It is a little heavier than Mahogany, but I have had no issues from it at all. It finishes beautiful and is great to work with |
Author: | PeterDeWitt [ Sun Nov 15, 2009 5:06 pm ] |
Todd, Does it matter how you orient the "grain" of the baltic birch ply when you use it for tail blocks? Thanks, Peter |
Author: | PeterDeWitt [ Sun Nov 15, 2009 10:43 pm ] |
Thanks, Todd. Peter |
Author: | truckjohn [ Mon Nov 16, 2009 8:36 am ] |
I think some sort of ply is almost ideal for the tail block... It is nice to have something hard to split. In my rooting around inside guitars... I have found almost every sort of wood blocks imaginable. I am surprised how often I see plain 'ole spruce, pine, and fir are used for both head and tail blocks..... Those guitars sound just find -- so in my mind... if those make good guitars (And they appear to..) you could use most anything. Thanks John |
Author: | truckjohn [ Mon Nov 16, 2009 8:40 am ] |
I think some sort of ply is almost ideal for the tail block... It is nice to have something hard to split. In my rooting around inside guitars... I have found almost every sort of wood blocks imaginable. I am surprised how often I see plain 'ole spruce, pine, and fir are used for both head and tail blocks..... Those guitars sound just find -- so in my mind... if those can be used in good guitars (they appear to..) I think you could use most anything. So far, I have personally just used whatever wood I used for the body... which is Mahogany, Cherry, and Oak. Thanks John |
Author: | Mark Groza [ Mon Nov 16, 2009 9:08 am ] |
I plan on useing ash, walnut, cherry, and maple in mine.I have some spanish cedar that i will use as well. |
Author: | woody b [ Mon Nov 16, 2009 9:13 am ] |
I've used baltic birch ply for end blocks, but I've used up all I had. I've got some Spruce top wood that isn't stiff enough. I'm going to make my own laminated end blocks from them while supplies last. I normally make my neck blocks from the same material the neck is made of, usually Mahogany or Maple. I don't see how Sapele would cause any problems. Todd, others, didn't Martin used to put a strip of Maple on the inside of their Mahogany tail blocks to help keep them from splitting? That might be a good idea with a solid end block. It could be made to look good if looks inside the box are important. |
